Slow Transfer to ESXi Datastore
Oswald_
I have enabled the terminal on my ESXi server and setup SSH access. This ESXi server is attached to my gigabit network. When I was doing a transfer of a VM using scp to the ESXi datastore my transfer rate was HORRENDOUS ... we're talking 800/kbps max.
So, I decided to try and enable FTP thinking that the crypto overhead of scp may be the problem. I'm currently transferring with the new rate of 1-2mbps using FTP. What is causing the slowness here? Any other transmission on my giga network is flawless and FAST why the slowdown to ESXi?
what type of datastore is it?
what is the link speed connection on the datastore device (assuming network attached)?
Are you using your current workstation as an intermediary in the SCP/FTP operation?
what else is on your network?
is the ESXi box and it's datastore device (for the storage traffic) on a separate physical switch, or a VLAN?
are the ESXi NICs on the I/O HCL?
do they have a ToE onboard?
what is your switch?
have you tried different physical switch ports?
have you tested the nics as good in another machine?
have you tested the cable?
what are your ping times like?
are the datastore drives busy doing other things, possibly causing a lot of head-seek, and significant slowdown?
SO not a valid test
The busybox is massively bottlenecked, it is guaranteed to perform like total unadulterated crap. :) Use the datastore browser to upload through the vmkernel stack.
The datastore is hosted on a iSCSI server with a gigbit nic
Answered above, gigabit
The VM's are being transferred from a external hard drive attached to the workstation and being uploaded via FTP
Kinda confused what you're looking for here ...
ESXi box and the iSCSI servers are on the same network which is seperate from the VM/Client network.
Not sure about the NIC but the server is a Poweredge 1900
No
ProCurve 2810
No
Really? Physically pull the NIC's from the server? Nope.
No?
bytes=32 time<1ms TTL=64
The iSCSI datastore these VM's are being transferred to is not in use at this time.
SO not a valid test
I'll give this a go and post back the results.
Buffalo TeraStations are very much not supported. How's your actual in-vm performance? Try a network copy in-vm.
I'm also noticing slow transfers to the local datastore of the server. I tried out of curiosity to upload the VM to the local datastore and I was getting about 5-10mbps.
Would this have anything to do with the VM's running while I'm transferring data?
Yes and no - as long as you're doing something through the busybox, it's going to be horribly slow. The ESXi busybox is a teeny vm with almost no resources. The only real way to test is in the VMs - what kind of performance do you get copying something from a network store to a VM's hard drive?
I just ran iperf on the VM (the VM was acting as the server) this is the output from the VM:
Code:
C:\>iperf -s
Server listening on TCP port 5001
TCP window size: 8.00 KByte (default)
[1872] local 192.168.4.216 port 5001 connected with 192.168.4.11 port 2605
[ ID] Interval       Transfer     Bandwidth
[1872]  0.0- 9.7 sec   343 MBytes   297 Mbits/sec
And here is the reverse:
Code:
C:\>iperf -s
[1856] local 192.168.4.11 port 5001 connected with 192.168.4.216 port 1111
[1856]  0.0-10.1 sec   378 MBytes   313 Mbits/sec
Transfers look fine. I'm just more and more confused by this.:confused:
wait, where did you run that? That actual transfer to the VM's drive?
Yes, that was a transfer from a workstation to the VM (IIS Server). Also from the VM to the workstation. The datastore for that VM is on the Buffalo.
Told ya. It's that the ssh/external storage stack is extremely limited. It's not supposed to be fast.
Depends- IIRC, the host version can be slow as snot too on ESXi. VC (if you have it) would be faster. Try downloading the virtual center trial, see if that version is faster :)
I'll give it a whirl.
Is it possible for a VM to access the underlying datastore filesystem? If it is, I could probably just transfer the VM's to a VM on the datastore and transfer them that way? If that makes any sense ...
