NightWolfe
- Sep 30, 2002
For some reason the transfer rate from my CD drive to my HD is incredibly slow .. this use to not be the case .. the setup when it worked fine is as follows ..
CD-RW & DVD-ROM on one IDE channel
HD & Zip Drive on the other IDE channel
then my DVD drive decided to crap out, so I took it out, along with my Zip drize since I didn't need it any more, then I put in an old 5GB HD for a little extra space .. my setup now is ..
CD-RW & 5GB Drive on one IDE Channel
HD on other IDE Channel
now since the CD and HD are on different channels the transfer rate should be fine .. any ideas ?
Equipment is as follows ..
HD = Western Digital Cavier 80GB 7200RPM 8MB Buffer
CD-RW = Sony 40X
OS = XP Pro .. Clean of Spyware/Viruses
all other info is in the sig ..
thanks for any help guys
CD-RW = Sony 40X
