Slow Read Spead on SDHC Card
Doom4life
Hey all,
In the process of coping ~32GB of data of my Lexar 32gb Class 10 SHDC and I'm noticing the read speed is only hovering around 10-11MB/s which seems a bit slow for me.
Is this right or is there something wrong with the card? The other thing I noticed was that my laptop was very finicky when I put the card in the slot. Took a number of times for me to actually view any folders, photos, copy files, etc.). In the past (with different cards), I had no issue with this.
What kind of files are you dealing with?
Many smaller files tend to result in a slower copy rate compared to a single larger file of the same size.
Could also be the laptop SD card slot going bad?
You can rule something out if you have another card and put in a large file (>200mb/ISO perhaps?) on both and checking the read speed.
Note the phrase "Class 10"
aka: That speed is as per spec for that card. Class 10 == 10 MB/sec write speeds.
The only cards that are faster are the UHS-1 cards but the reader has to support those.
Hey all,
Nope, that's right on the button for Class 10.
http://kb.sandisk.com/app/answers/d...eed-class,-uhs-speed-class,-and-speed-ratings
