Hi,
I'm running into a peculiar issue while on VPN connection using OpenVPN on a Lenovo laptop.
Lenovo laptop is T560.
Using OpenVPN config file provided by my VPN provider.
Tested on Ubuntu and Windows 7 using laptop Wifi, laptop LAN and dongle LAN.
Tested the same OpenVPN config on different laptops (non-Lenovo) and PCs.
I kept the config the same between tests, the only thing that changed was OS (Ubuntu vs Windows) and hardware (built in LAN/WiFi vs Dongle LAN [over USB 3.0]).
I'm using speedtest.net to run the tests.
Results:
Lenovo Windows 7 LAN - slow
Lenovo Windows 7 WiFi - slow
Lenovo Ubuntu LAN - slow
Lenovo Ubuntu WiFi - slow
Lenovo Windows 7 Dongle LAN - slow
Lenovo Ubuntu Dongle LAN - NORMAL
I also have another Lenovo laptop, T460 (or 480) running Win7 which also runs slow over OpenVPN. The T460 I tested long time ago but remember it behaved similarly to T560.
When I connect to my provider VPN over PPTP (Windows VPN connectivity) the speed is NORMAL, so it is only OpenVPN that is running slow as shown above.
What works. A non-lenovo Ubuntu laptop (older than my T560) over Dongle LAN (same dongle used in T560 testing) and internal WiFi. A PC over LAN running Ubuntu and a mini-PC over LAN running Ubuntu.
Any ideas?
Thanks.
Results:
Any ideas?
Thanks.
