I'm having a strange issue for a long time that I've never been able to fix.
I've a desktop, wired to a d-link 524 router (54mbps), and a laptop connected wirelessly to it. Both machines are running fully updated XP SP3, clean install, no AV/Firewalls in between. File transfers between both computers never go above 2MBps, unless I connect the laptop to the router by a lan cable. That way, I can get up to 6~7MBps transfer speeds, which are reasonable to my router speed.
HOWEVER,
When both machines are running Vista, this problem doesn't happen. Transfer speeds between machines (desktop wired, laptop wireless) always go at full speed (nearly maxing out the router's 54mbps limit). This doesn't apply when one computer is running Vista while the other XP. So, only Vista-Vista setup works properly.
I've tried different drivers for the laptop's wireless nic, and also tried different nics at desktop, and none helped. I believe this is some kind of configuration at windows XP, but I've searched quite a lot and so far to no avail. Can anyone shed some light on this?
tl:dr version:
Wired Desktop XP --- Wireless Laptop XP = 2MBps tops;
Wired Desktop XP --- Wired Laptop XP = 6~7MBps (which is good considering it's a 54mbps router);
Wired Desktop Vista/XP --- Wireless Laptop Vista/XP = 2MBps tops;
Wired Desktop Vista --- Wireless/Wired Laptop Vista = Almost constant 8MBps (nearly maxing out the router capacity);
HALP!
HOWEVER,
tl:dr version:
HALP!
