I'm having an issue with slow transfers that hasn't happened since I upgraded to a "real" hardware RAID card. I have a Sans Digital TR5M-B that came with a crappy little software RAID controller. I ditched it after recommendations from the good folks here and got a RocketRAID 2314. I've had zero issues with it before upgrading to Win10.
The enclosure houses five 2TB Western Digital Red drives. The system has an AMD A10-6800K CPU on a Gigabyte FM2+ motherboard with 8GB of RAM. I haven't changed anything in the array or in the controller card's BIOS for many years.
Basically, I start at 150 MB/s or so when copying from the array to any other drive in the system, then drops down to 8-9 MB/s within about 15 seconds. Originally, I thought it was a USB 3.0 driver issue, since I have an external Seagate 5TB and Western Digital 4TB drive I was trying to copy everything in the array to. I got three new Western Digital 5TB drives that I planned on installing in that enclosure, so I needed to get everything off the old drives. To eliminate the other drives, I copied to/from the USB drives themselves, which should be the slowest of all combos. I get a steady 140-150 MB/s from the Western Digital 4TB external to the Seagate 5TB external. I get roughly the same speeds going from internal spinning disks and SSD. I've already updated every single driver in the system. The newest drivers I can find for the RR 2314 are from 2013 (on their site). I've also enabled all the faster write cache settings on all the drives, as the system is on a beefy battery backup, and a little dataloss wouldn't be the end of the world.
If I can't figure this out, I may just try to find room in the case for the three WD 5TB drives and go to the RAID on the motherboard. Thanks in advance.
