I'm running an Areca 1220 on a FreeBSD machine with 2 arrays on it
4x seagate 320gb in raid5
4x samsung 750gb in raid5
The machine is a s939 dual core (3800+) with a gig of ram.
Firmware version V1.43 2007-4-17
Doing a read test on the arrays (using bonnie++) is only yielding about 90MB/s read speeds, which seems awfully low for what it could be. CPU/memory usage don't seem to be the bottlenecks, so I'm unsure where the problem is.
Here are some screenshots of the config (ignore the checking state, I started that up after the benchmarks, and it has no effect on this), my fstab, some camcontrol inquiry information, and my dmesg output. Everything seems to be alright to me, so I'm at a loss for this poor performance. Any input would be appreciated.
http://fryguy.rattlesnake.ath.cx:81/raidprobs/fstab
http://fryguy.rattlesnake.ath.cx:81/raidprobs/dmesg
http://fryguy.rattlesnake.ath.cx:81/raidprobs/raid1.png
http://fryguy.rattlesnake.ath.cx:81/raidprobs/raid2.png
http://fryguy.rattlesnake.ath.cx:81/raidprobs/raid3.png
Code:
rattlesnake# camcontrol devlist
<Areca Seagate Raid5 R001> at scbus0 target 0 lun 0 (pass0,da0)
<Areca ARC-1220-VOL#01 R001> at scbus0 target 0 lun 1 (pass1,da1)
<Areca RAID controller R001> at scbus0 target 16 lun 0 (pass2)
rattlesnake# camcontrol inquiry 0:0
pass0: <Areca Seagate Raid5 R001> Fixed Direct Access SCSI-5 device
pass0: Serial Number 0000004267179126
pass0: 166.666MB/s transfers (83.333MHz, offset 32, 16bit), Command Queueing Enabled
rattlesnake# camcontrol inquiry 0:0:0
rattlesnake# camcontrol inquiry 0:0:1
pass1: <Areca ARC-1220-VOL#01 R001> Fixed Direct Access SCSI-5 device
pass1: Serial Number 0000002877601663
pass1: 166.666MB/s transfers (83.333MHz, offset 32, 16bit), Command Queueing Enabled
