slow (2.4x) DVD burning with multiple drives
JamesH
so i have been working on this computer for months, it has 3 dvd burners and if i use all 3 at once it burns SLOW (25min for 4gb)
each drive is a LiteON SHW-160P6S with the most recent firmware off the liteon site
the harddrive feeding the ISO's is a WD 160GB sata drive
each cd drive is alone on each port, the two IDE ports on the motherboard have a DVD drive each, and one drive is on a promise ultra 133 tx2
here is the log file from my most recent attempt:
Code:
########################### System Information ###########################
  Windows XP Professional 5.1 Service Pack 2 (Build 2600)
  Processor info: AMD Sempron(tm) Processor 2600+ (1599MHz)
  Memory Available to Windows: 523,760 KB
############################ Program Information ###########################
  File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
    Company Name: Alcohol Soft Development Team
    Description: Alcohol 120%
    Original: Alcohol.exe
    Product: Alcohol 120%
    Trademarks: Alcohol Soft Development Team
    Copyright: Copyright(C) 2002-2007 Alcohol Soft Development Team
    Version: 1.9.6 ( Build 5429 )
    Date: 2007/11/27
  File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
    Company Name: Alcohol Soft Co., Ltd.
    Description: Alcohol virtual device control library
    Original: alcoholx.dll
    Product: Alcohol
    Copyright: Copyright (C) 2000-2006
    Version: 4.10.0 ( Build 0 )
    Date: 2007/06/04
    Hash: *****
  File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
    Description: Alcohol Software Device Capability Library
    Original: devsupp.dll
    Product: Alcohol Software Device Capability Library
    Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
    Version: 2.5.2 ( Build 604 )
    Date: 2007/07/02
    Hash: ******
########################### User Information ###########################
  Licensed to: ******
  Registered User ID: *****
########################### Options Setting ###########################
  Devices control interface: Default Driver Control Interface
  CPU Priority Level: High
  Memory Buffer Size (MB): 204
  Examine the accuracy of data read from physical device: Yes
  Enable Enhanced Weak Sector Scanner during dumping: No
  Overburn disc(s): No
  Turn off "Auto-Select best write speed" function if possible: No
  Fill memory buffer before recording discs: Yes
  Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
  Ignore Media Type: No
  RMPS (Recordable Media Physical Signature) Emulation: No
  BAD Sectors Emulation: No
  Sub-Channel Data Fixed & Emulation: No
  Laserlock Emulation: No
  Current Language: English
############################ Device(s) List ############################
  (D:) LITE-ON DVDRW SHW-160P6S  (nvatabus, Port 1, Bus 0, Target 0, Lun 0)
  (E:) LITE-ON DVDRW SHW-160P6S  (nvatabus, Port 1, Bus 0, Target 2, Lun 0)
  (F:) LITE-ON DVDRW SHW-160P6S  (ultra, Port 0, Bus 0, Target 0, Lun 0)
  (G:) UU0593C NKE605B           (ahw4rtqs, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
  1394BUS.SYS   ACPI.sys      afd.sys       ahw4rtqs.SYS  ALCXSENS.SYS
  ALCXWDM.SYS   ANV4DISP.DLL  anvioctl.sys  ANVMINI.DLL   AnyDVD.sys
  arp1394.sys   asuskbnt.sys  atapi.sys     audstub.sys   avg7core.sys
  avg7rsw.sys   avg7rsxp.sys  avgclean.sys  avgtdi.sys    Beep.SYS
  BOOTVID.dll   Cdfs.SYS      cdrom.sys     CLASSPNP.SYS  disk.sys
  dmio.sys      dmload.sys    drmk.sys      dump_nvatabus.sys dump_WMILIB.SYS
  dvd43llh.sys  Dxapi.sys     dxg.sys       dxgthk.sys    EIO.sys
  ElbyCDIO.sys  Fips.SYS      fltMgr.sys    Fs_Rec.SYS    ftdisk.sys
  hal.dll       HIDCLASS.SYS  HIDPARSE.SYS  hidusb.sys    HTTP.sys
  i8042prt.sys  imapi.sys     ipsec.sys     isapnp.sys    kbdclass.sys
  KDCOM.DLL     kmixer.sys    ks.sys        KSecDD.sys    memacc.sys
  mnmdd.SYS     mouclass.sys  mouhid.sys    MountMgr.sys  mrxdav.sys
  mrxsmb.sys    Msfs.SYS      msgpc.sys     mssmbios.sys  Mup.sys
  NDIS.sys      ndistapi.sys  ndisuio.sys   ndiswan.sys   NDProxy.SYS
  netbios.sys   netbt.sys     nic1394.sys   Npfs.SYS      ntdll.dll
  Ntfs.sys      ntkrnlpa.exe  Null.SYS      nv_agp.sys    nv4_disp.dll
  nv4_mini.sys  nvatabus.sys  NVENETFD.sys  nvnetbus.sys  NVNRM.SYS
  NVSNPU.SYS    ohci1394.sys  PartMgr.sys   pci.sys       pciide.sys
  PCIIDEX.SYS   Pcouffin.sys  portcls.sys   processr.sys  psched.sys
  ptilink.sys   rasacd.sys    rasl2tp.sys   raspppoe.sys  raspptp.sys
  raspti.sys    rdbss.sys     RDPCDD.sys    rdpdr.sys     redbook.sys
  SCSIPORT.SYS  serenum.sys   serial.sys    sptd.sys      sr.sys
  srv.sys       swenum.sys    sysaudio.sys  tcpip.sys     TDI.SYS
  termdd.sys    ultra.sys     update.sys    USBD.SYS      usbehci.sys
  usbhub.sys    usbohci.sys   USBPORT.SYS   vga.sys       VIDEOPRT.SYS
  VolSnap.sys   wanarp.sys    watchdog.sys  wdmaud.sys    win32k.sys
  WMILIB.SYS
################## Detailed Information of Device(s) ##################
    (D:) LITE-ON DVDRW SHW-160P6S(1:0) detail information.
    Vendor Identification: LITE-ON
    Product Identification: DVDRW SHW-160P6S
    Production Revision Level: PS0B
    Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
    BURN-Free Technology: SMART-BURN
    Auto-Select best write speed: SMART-BURN
  -* Note: This information below is provided by the unit, it might be inaccurate. *-
  -* This software does not use this information!                                  *-
      Removable media: Yes
      Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
      Response Data Format: 02h
      CD-R Read/Write: Yes/Yes
      CD-RW Read/Write: Yes/Yes
      Read CD-R Fixed Packet: Yes
      Test Write: Yes
      DVD-ROM Read: Yes
      DVD-R Read/Write: Yes/Yes
      DVD-RAM Read/Write: No/No
      Audio Play: Yes
      Composite Audio and Video Data Stream: No
      Digital output (IEC958) on port 1 Supported: Yes
      Digital output (IEC958) on port 2 Supported: No
      Mode 1 Form 2: Yes
      Mode 2 Form 2: Yes
      Multi-Session: Yes
      BUF: Yes
      CD-DA Commands supported: Yes
      CD-DA Stream is Accurate: Yes
      R-W Supported: No
      R-W De-interleaved and Corrected: No
      C2 Pointers Support: Yes
      ISRC Supported: Yes
      UPC Supported: Yes
      Read Bar Code: No
      Lock media into the drive: Yes
      Currently drive Lock state: Unlocked
      Prevent Jumper: No
      Eject Command: Yes
      Separate volume levels: Yes
      Separate channel mute: Yes
      Changer Supports Disc Present: No
      Software slot selection: No
      Side change capable: No
      P through W in Lead-In: Yes
    (E:) LITE-ON DVDRW SHW-160P6S(1:2) detail information.
      Test Write: Yes
      DVD-ROM Read: Yes
      Audio Play: Yes
      Mode 1 Form 2: Yes
      Mode 2 Form 2: Yes
      Multi-Session: Yes
      BUF: Yes
      R-W Supported: No
      ISRC Supported: Yes
      UPC Supported: Yes
      Read Bar Code: No
      Prevent Jumper: No
      Eject Command: Yes
    (F:) LITE-ON DVDRW SHW-160P6S(0:0) detail information.
      Test Write: Yes
      DVD-ROM Read: Yes
      Audio Play: Yes
      Mode 1 Form 2: Yes
      Mode 2 Form 2: Yes
      Multi-Session: Yes
      BUF: Yes
      R-W Supported: No
      ISRC Supported: Yes
      UPC Supported: Yes
      Read Bar Code: No
      Prevent Jumper: No
      Eject Command: Yes
###################### Source Disc/Image Information ######################
Type: 	Standard ISO Image file
Path: 	C:\
Session: 	1
Track: 	1
Session 01:
  Track 01: DVD, Length: 2172276(4.14 GB), Address: 000000
####################### Dumping/Recording Progress Log #######################
********* Time 11/27/2007 5:15:44 PM *********
17:15:45 Processor info: AMD Sempron(tm) Processor 2600+ (1599MHz)
17:15:45 Memory Available to Windows: 523,760 KB
17:15:45 Memory Buffer size: 204 MB
17:15:45 Image file loading: C:\AMERICAN_GANGSTERs.ISO
17:15:45 DVD Source Info:  Session: 1, Track: 1, Length: 4.14 GB / 482:43:51
17:15:54 (D:) LITE-ON DVDRW SHW-160P6S(1:0): Recording Method/Speed
17:15:54 Recording - DVD DAO - 6.4X (8864 KB/Sec)
17:15:54 (E:) LITE-ON DVDRW SHW-160P6S(1:2): Recording Method/Speed
    (D:) LITE-ON DVDRW SHW-160P6S(1:0) - Media format: DVD-R
17:15:54 (F:) LITE-ON DVDRW SHW-160P6S(0:0): Recording Method/Speed
    (E:) LITE-ON DVDRW SHW-160P6S(1:2) - Media format: DVD-R
    (F:) LITE-ON DVDRW SHW-160P6S(0:0) - Media format: DVD-R
17:38:08 Image file loading completed!
17:39:07 (D:) LITE-ON DVDRW SHW-160P6S(1:0): Recording completed successfully!
17:39:07 Elapsed Time:  00:23:12, Average speed: 2.3X
17:39:10 (E:) LITE-ON DVDRW SHW-160P6S(1:2): Recording completed successfully!
17:39:10 Elapsed Time:  00:23:15, Average speed: 2.3X
17:39:32 (F:) LITE-ON DVDRW SHW-160P6S(0:0): Recording completed successfully!
17:39:32 Elapsed Time:  00:23:38, Average speed: 2.3X
17:39:39 All recording procedures have been completed!
17:39:39 Elapsed Time: 00:23:46
if noone can find anything, i'm gonna put the drives in my box (a64 3000+, 1gb ram, ubuntux64) -- we just want to be able to burn at a decent speed (8x atleast, 16 would be nice since all the drives support it)
