Slot load your external SATA
nightanole
Well this is more of a combo then a deal. anyways heres what i did this turkey day.
get yourself a lan-li 5.25 sata/ide external case EX-127
http://www.coolerguys.com/840556007319.html
http://www.newegg.com/Product/Product.asp?Item=N82E16817273001
then bebop over to meritline for there trayless slot loading sata rack.
http://www.meritline.com/i-rack-internal-sata-drive-tray-less-design-with-fan-lock.html
http://www.meritline.com/ez-rack-internal-sata-drive-tray-less-design-with-lock.html
So for about $60 you can slot load all of your sata drives, which makes them alot easier to work with, and is alot safer then using a sata2usb adapter and leaving it on the table. Mine kept my perpendicual barely warm to the touch after an hour solid of transfering files. and that was before i removed the fan grill that blocked half the fan.
