I just picked up a slot loading DVD/RW drive and had a couple questions for anyone with experience with pc-based slot loading drives. I feel that mine (Pioneer DVR-TS08) may not be behaving properly.
First, how much noise are they supposed to make when inserting or ejecting discs? This thing makes three loud clicks every time I put a disc in or eject it. From looking through the bottom of the drive, it appears that the drive is attempting to grab onto the disc multiple times and always gets it on the third attempt.
Second, to what extent should it pull the disc into the drive itself? I have to push the disc 2/3 in before the drive even attempts to pull the disc in to it and even then it just spins. I have to help the drive pull the disc in far enough where I can no longer touch it. It ejects the disc far enough where only 1/3 of it is still inside.
Is the first behavior normal but the second not? That's my thoughts on the drive's behavior.
