Slot 1 to Socket 370 Adaptors
Maniacmous
I've been searching all over the internet to try and figure this out so here goes:
I want to upgrade my girlfriend's computer which is ridiculously slow (P3 500mhz Slot 1 processor and 128MB RAM, more of which I've already got ready to go), but it's gotta be pretty cheap...because I too am a poor ass college student. Around here, I've got a 1ghz+ PIII hanging out, but its a Socket 370 - so I figure I can just use the adaptor and bam, instant, very cheap upgrade (as the adaptors are only like 10 bucks).
My question is: has anyone used one of these things and know how a HSF attaches to them? I have Googled them, read reviews, checked out Powerleap, nothing on what kind of HSF to use nor how to attach it (If I have to use Thermal Adhesive, so be it).
So...my question to you fine people is: what kind of HSF (or a link would be great) should I use...and just how should I attach this thing?
I've used many hundreds of the adapters and would highly recommend the Powerleap units as they are much better constructed, fit more secure in the slot 1 brackets and use an additional power connector for it's onboard voltage regulator to avoid over/undervolting the processor which the lesser slotkets can do if the motherboard doesnt support the correct voltage. They use regular S370 heatsinks, I've mostly used the stock Intel HSF's that came with P3 1+ Ghz and Tualatin based Celerons and they fit fine. You won't be able to fit a real large heatsink, but the CPU's in question don't need a huge one anyway.
I am running a socket 1ghz in my Asus P3V4X board and it works great. I am just using a cheap Slot 1 adaptor which happens to work good. Make sure you get a decent hsf since the cheap one I bought had the fan stop sometimes when powering up and I overheated my chip. Now it runs at 945mhz. At 1ghz, the machine is unstable.
Called Slockets :p (Slot/Socket)
Only thing you need to worry about is voltage and if the motherboard is compatible.
Rad777
Rad777
One of the better slockets (and one that I used to use) is MSI's Slocket Master.
It works with *any* S370 processor, includes easy-to-follow instructions about setting CPU speeds, can use most S370 fans, and even works in SMP rigs.
If the motherboard can use the CPU iin a Slot 1 config, the Master with the same CPU in S370 will work.
The whole idea with slockets is that some motherboards (especially earlier VIA Apollo Pro 133 chipset boards) that had both Slot 1 and Socket 370 had a problem with 133 MHz S370 CPUs (as in they wouldn't work) while Slot 1 CPUs of the same speed *would* work.
I had a TYAN Trinity with this ugly issue: I had a S370 P-III 1 GHz that I had wanted to use with it; however, the S370 socket would not swallow a CPU with 133 MHz FSB. The Slot 1 side could, which told me I needed a Slocket.
The Slocket stood me in good stead until I lucked out and bought an ABIT VP6 at a good price (said VP6 is still in use today).
i have a modded asus slotket that runs tualatin in 440bx boards :D i had my celeron 1300@1600 in an old soyo 6ba+iv
I have an Iwill slocket and have used the stock heatsink and the larger PEP66 heatsink. It has worked flawlessly. See what the max cpu speed your mobo can take.
if its a bx board, or doesnt support 133fsb, the celeron 1.1 and maybe the celeron 1.4 would be the fastest you could get.
