The low profile 4-heatpipe AMD s939/am2 heatsinks work a whole lot better then the old slot1/a stuff.
the task of cooling a GTS250
Google:
slot 1 site:dansdata.com
GTS250 TDP: 150W
Pentium III 1GHZ Slot 1 TDP: 35W
See the problem?
Remember the Alpha K7125?
I agree, but the dimensions won't work for my application. My thought was that the relatively long, and skinny, heatsink would be an easier fit for the similarly long and skinny half-height video card.
I really do wish there were aftermarket options available, but the small "orb" gpu coolers of days past just aren't up to the task of cooling a GTS250, and everything modern seems to be trending up in size, not down.
Yeah they where 60mm 47dbishh 36-38 cfm and 6.8-7k rpm, used to run 4 of them in the slotA days, nowadays have a hard time enduring anything over 33db....
Those slot coolers are just begging to have their stock shrouds removed and 120mm fans slapped on them. What better way to make such a system super quiet.
