Slk900u + 3200+
Tengis
What can I expect? I cant put the multiplier up past 11.5 (.5 from normal)... and the FSB wont go past 408. Should I throw some voltage my cpus way? Whenever I go past that I get "cpu dumping" blue screens (what are cpu dumping bluescreens anyways?). I have Kingston HyperX pc3200... I feel my ram is limiting me, Im going to grab some 3500.
if you're voltages are still stock, yes up them a little.
maybe even bump up the ram voltage and/or loosen the timings.
I put up the voltages by .1 on the ram, and .75 on the cpu (I think). Im on an Abit nf7s 2.0, I put up the voltages one setting from stock.
What exactly are bad voltage settings/too high? I need some guidlines.
Also, Im really only concerned about my ram. I cant really monitor its temperature... so... would the voltage being increased make it too hot in any way?
Thanks for your input!
.1v is almost guaranteed to be no problem on the ram.
I think I've got mine at .2 over and have seen no problems at all...I do have a blowhole positioned directly over the ram though, don't know how much of a difference it's making.
as for the cpu, the limit is somewhere near 2v if I'm not mistaken, but most people are a lot more comfortable stopping early in the 1.9x range
