Slipstreaming updates separate from OS
DB773
Windows 7 SP1: So far, all of the slipstreaming articles I've found talk about integrating the updates with the OS .iso and end up with one disk. What about creating an installer disk having just the updates? Has it been done or will it work?
You can create an install script, if that is what you're looking for. Just put all of the updates in a folder and use a batch file to loop through them.
Code:
for %f in (dir *.msu) do wusa "%f" /quiet /norestart
That command line will install all MSU updates in the current folder. You will need to adjust it to work inside a batch file.
Thanks for responding, Demon10000. Now I need to learn programming! (Because, out of curiosity, I'm trying to see if that code points to the folder with the .msu's.) Anyway, I was picturing that some slipstreaming software would do the task.
I've always had good luck integrating directly into the disc. It saves you a lot of time because the updates will be installed with the OS. The installer script idea really isn't that different than using Windows Update, except the files are already downloaded. My current Windows 7 disc has around 300 post SP1 hotfixes and security updates.
Because so many updates are superseded, what I do is install Windows 7 onto a box then go through and write down the KB's of all the updates it wants to install, then download them with a WSUS offline program and slipstream them into the disc, then reinstall to verify the disc is right. At home this is probably not worth the trouble, but at work when I'm doing clean installs of 7 quite often, this saves me time in the end.
I see the time saving benefit of letting Win 7 tell you what updates are needed. I've just downloaded the updates that a list on Win Toolkit pointed me to and so I may have more than is needed. I like your idea bigdogchris. I think I'll go that route.
