slim pc video card problem
tfcmaximus
I am currently trying to figure out a solution for this product by Asus:
http://www.asus.com/products4.aspx?modelmenu=2&model=502&l1=1&l2=3&l3=0
Supposedly from people that have used this report the onboard video card does not support widescreen resolutions at all.
Well I am trying to innovate I guess you could say a really slim pc small enough to fit somewhere in my truck so I can have a computer connected to my mobile video unit.
I think I am able to make all the right input/output connections, but please I am asking for someone to help me solve this resolution problem. I need the resolutions compatible with car mobile video units so that I can run windows onto them. Is there any products that can make this possible. I want an actually computer. Doesnt need to be gaming compatible pc, just something similar to the link provided. Are there units already out there designed for the car that can run winodws? If so please point me in the right direction, I was quiet surprised this idea hasn't already taken off and if it has I am defintely out of the know.
I was thinking what I really want is the hardware part of the laptop. You know without the keyboard or display so I could slide it under the seat or something. Any ideas or anything would help, thanks alot.
There are non-upgradable HPs at Best Buy that are smaller than my 4 slot toaster.
HP Slimline
Product Height 9.75"
Product Width 4.4"
Product Depth 13.1"
Product Weight 14.2 lbs.
