Slim mATX case with vertical GPU mounting.
1337Goat
Slim. Lithe. Tight. Powerful.
This is going to be a media PC, which lies on its side flat.
I want it as small and flat as possible, so let me know if you have any case recommendations.
I built a PC with a Rosewill R379-M many years back (10+ maybe) mainly because it was inexpensive. For size they are mostly just like this.
There's one or two in the sff forum. Workin now, but there are some more on amazon/newegg, etc that I know of. Will lookem up later.
Reactions: Nobu
There's also this one if you like a slim form factor, somebody put a mATX threadripper build into a Salvo Studios S401
Reactions: Nobu
You want a flat case that lays like a pizza bx, right?, but do you want the GPU parallel to the motherboard, or perpendicular/?
It's much easier to do horizontal (without limiting your to half-height cards.)
Also, you're going to find a lot more custom Mini ITX cases in that category, so be prepared to compromise. As ther have said, check out the SFF forum.
