Slim 140mm Fans?
Synomenon
Anyone know of any slim 140mm fans that can be purchased in the USA?
I need a slim 140mm fan for an upcoming build w/ a Thermalright AXP-140.
This is what it looks like w/ a 120x20mm fan:
The ledges on the heatsink at each end of the 120mm fan are for mounting a 140mm fan. So it looks like the 140mm fan would have to be slimmer than 20mm.
I'm using the AXP-140 because it covers over both sticks of RAM and the chipset heatsink on my motherboard and a 140mm fan on it would cool everything.
If I can find a slim 140mm fan, I'd also remove the noisy 80mm fan from the PSU.
Last thing. The case is a SilverStone SG05. It has a single 120mm intake fan in the front. This is what the airflow is supposed to look like:
Fresh air is supposed to be sucked into the case by the front intake then exhausted by the 80mm PSU fan. However, Thermalright recommends installing the fan on the AXP-140 so that it blows downwards / into the AXP-140's fins. This is opposite of how the airflow is supposed to go.
What should I do w/ this setup (assuming I can find a slim 140mm fan to put on top of the AXP-140)? Follow SilverStone's intended airflow path (and have the 140mm fan on the AXP-140 blow upwards into the PSU (which has had its 80mm fan removed) or follow Thermalright's recommendation and have the 140mm fan on the AXP-140 blow downwards into the AXP-140's fins and onto all the components below the AXP-140?
The ledges on the heatsink at each end of the 120mm fan are for mounting a 140mm fan. So it looks like the 140mm fan would have to be slimmer than 20mm since it's mounted higher.
