slim 120mm fans?
Santasballz
are there any slim 120mm case fans? most of them are 25mm in width, are there slimmer ones?
quiet would be a bonus too, thx
I'll have to search for the link, but I found a 120 (I think) in 15mm.
please do. i've been searching on google for awhile. i've found slim 80mm fans, but not 120. thx!
I'm really not sure if there are quiet 15mm wide 120's. The orange Nexus 120mm is the quietest 120mm out there but at 25mm wide, and I havent seen any 120mm fans thinner then that. If there are 15mm 120's, I'm not sure it'll be silent, or as quiet as the Nexus.
you could try and find a cheap PSU that uses a 120mm fan, as those are mostly 15mm wide fans. Then you can rip the fan out and re-tail it yourself.
if it's not as quiet as you want, try undervolting it. Most mid and low speed fans play well at 5v.
