Sliding side door fan question
Domingo
Hi everyone, I'm currently using a Thermaltake Element G, which I really like.
http://www.thermaltakeusa.com/products-model.aspx?id=C_00002089
One of the main things I like about it is that it has a large fan in the sliding side door with no wires. When you slide it into place, it automatically comes on thanks to a connector built into the door itself.
Do (m)any other cases have this?
I remember Zalman using a similar feature on one of their cases... but that's about it. If you're a handy sort, you'd be able to rig up something similar, I'm sure.
Our KL01, KL02, and KL03 cases (released in 2007) had this feature for their front fan.
