Sliding Rack Rails and Rackmount Depth Adapters
Degsy
I have an XCase RM420 v2 (same as the Norco 4220) and 4 x Rackable Systems C2004 cases that I need sliding rails for, to install them into my Dell Poweredge 4210 server rack. I can get a generic set of rails for £35 which are advertised as 26" (66cm) but the depth of my server rack at the moment is 72cm (~28") to accommodate my IBM 1U KMM.
I have seen a rackmount adapter kit that would allow me to work around the difference in mounting depths but the price of it is £70-80 :eek: and they're for round-hole to square-hole conversions (http://www.iblparts.co.uk/rackmountadapterbrackets.html)
Basically, I need 5 sets of sliding rails and a 1U rackmount adapter that will allow me to decrease the depth of my KMM so that I can move the rear mounting posts to accommodate the sliding rails for the cases. The cheaper the better :)
Thanks,
Degsy.
You won't need any adapters. The distance between posts in my rack is 29" and I'm using 26" rails.
the posts on my rack are 3" wide, you can mount on either side for 29" or 26" depth.
square holes on all surfaces of the posts so you can rack nut anything.
Thanks for the info :)
Does anyone have any links (in the UK) for cheap generic sliding rails?
