Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My friend has the newest drivers the 91.31 with 2 7900 gtx in SLI, and he cant figure out how to turn the green bar on the right hand side off. He cant find the location to turn it off. Can anyone give a clue where to look?????
If your using the new control panel , open it. Click on the 3D setttings icon , once that openes up you will see the words "3d settings" at the top next to the word, view. Click the drop down and you will see the words "show sli visual indicator" if you click it will select/deselect the option like a toggle switch
