SLI - Top card temps
Yaden
I am running a pair XFX Geforce 7800GTs and now running 2 different aftermarket coolers on them.
Top:
http://www.newegg.com/product/product.asp?item=N82E16835118001
Bottom:
http://www.newegg.com/product/product.asp?item=N82E16835186001
I can't swap them around because of the bolts on the back of the Zalman. Orginally I had stock cooler on top card and AC cooler on bottom card. With that setup and current one, I notice my top card is always 10C degrees warmer than the bottom. Is this to be expected?
Also, checking temps with Nvidia's Display, GPU #1 is the top card, right?
edit: not my day for spelling, lol
The 1st card will be warmer due to it having to do 1/2 the rendering plus combining the data images. It runs warmer, bacause its doing more work.....
Not to mention it has the burning hot ic's from the back of card 2 right in it's face..
Yeah, I assumed it had to do with how close they are together - which is why it is definitely nice to see the newer mobos with more space there. I'm going to stick with my current setup, at least it is a litter quieter now. Thanks.
Heat rises.. when I had an ATX config, gpu1 (the "top" card) would be warmer.. but in BTX, well, with the slots on top, over the cpu.. (lianli vXXXX cases and others) gpu2 runs warmer now... I don't think it has much to do with the final image assembly, but just simple thermal dynamics.. heat pools between the cards and that causes the top GPU to run warmer than the bottom. If it's bothering you, get some air between those cards! like a Logisys Edge 3d fan card or something.. should help cool things down.
Well, guess I found my problem...
With side case fan blowing out, my temps would hit 72C top and 46C bottom - with fan blowing in, they both stay steady at 42C or so. I need to do a little more testing but I was surprised what a difference it made.
(btw, I have top card's fan turned all the way down)
id say this is pretty normal if you have bad air flow... i know i do which is why im researching water cooling. when im running sli you can be pretty sure that the bottom card is a solid 10c higher. i assume this is because the heat goes down, hits my x-fi card (even with a empty pci slot between them) and bounces back up. during my testing i usually stick a fan in front of the pc to find out what kinda clocks i can get with a better cooling solution and they stay very close to the same temps.
I noticed a problem with my setup last night. Was watching temps and was running NFS:MW.... noticed only the GPU1 temps were rising... it even hit 91C, while the low card hit only 62C at the highest
SLI Inno3d 6600GT's on identical SVC705AL coolers. w/ a 120mm fan blowing air in from the outside of the case.
Strange, I change SLI rendering mode from Auto, to Alternate frame, to SLIAnti...same results, even with ATI Tools... only the top card went hot by a huge margin.
Before yesterday, the temp difference of the two were only 1-2C only.
Could it be I need to refit the top cooler? (Was thinking of swapping the two to test if the cooler is the culprit or my driver settings - 91.33)
91C seems really high for a 6600GT but I haven't used one in a while, so dunno other's temps.
Yup, boy was it high!
Anyway, figured it out. The fan was loose, hence not spinning smoothly. Just pushed it back into place and checked if it spun freely. Now my top card is only 2C off from the bottom.
That sounds about right... my top card idles about 1c higher than the bottom one.. in heavy game play it can go to 3c more.. or even higher if the ambient is over 33C or so (90+ in F).
