SLi tester?
Just make sure its not a virus or Trojan, the poster only has two posts and he says he has no SLI setup.
clamAv reports it as clean, but how would you even consider writing a utility for hardware that you dont own/have access to?
Guess and check.
robberbaron said:
Guess and check.
since its now well known how nvidia creates the profiles, its pretty easy to write it. testing it, well that requires the hardware
