pyrogx2000
- Dec 18, 2001
Using 2xGTX680 (EVGA)
Win 8.1 Pro 64 Bit
nVidia driver: any
I noticed while using Windows Movie Maker, the entire screen flashes black/white when mousing over any part of that window.
I found out that suddenly SLI is not enabled at all, and I have no option in the control panel to turn it on.
SLI has been working for a month, I confirmed its working using EVGA precision X going out to my G510 keyboard and was able to see both cards working.
I have 3 different SLI bridges, and have swapped out all of them, does not work.
I have reseated both cards, and rearranged all ends of the power coming from the power supply.
I have uninstalled and clean installed same, and older drivers.
If I pull the bridge out and leave it that way, I get what you see in the attached picture: SLI option will appear but I cannot enable it, as it says I need to connect the bridge.
When I reconnect the bridge (after power down), the SLI option vanishes entirely.
Both cards show up in device manager.
I used the 'Clean installation' option when installing same/older drivers from nVidia (but that probably doesnt help)
I will be honest and say that I recently upgraded my CPU/Motherboard/RAM, and added this second card WITHOUT reinstalling windows. However, everything was working for a month. I did NO updates of any kind.
I would be happy to reformat if it would solve, as 8 hours of driver cleaning would drive me mad.
Please help! Thanks.
Win 8.1 Pro 64 Bit
nVidia driver: any
