SLi Questions
J4M3S0N79
OK,
A SLI setup with a 939 90nm will be my next rig, but I do have some questions. Physically, how is sli done. I know that ther is a little connector inside the case that physically connects the cards, but do you also have to use a pass through cable? Probably not huh. Also, any opportunity for using quad mons? That would be the best! I need 4 172x in a big panel! I would do like an upsidedown T config!
M
as far as I know, the setup for consumers doens't yet exist....the best thing you can do is google nvidia SLI, and start reading. That, and wait until PCI-E SLI boards come available, and consumers can get the parts....then come back here and ask...im sure someone here will be on the bleeding edge of that :)
Also take note, the only 2 cards supporting SLI (Both PCI-E only) are the 6800 Ultra (not out) and the 6600GT (out).
