I currently have 3 monitors hooked up to my 9600gt and 7900gtx (30-22-20 inchers). The primary use of my computer and monitor space is for Poker. I don't game heavily but with Empire:Total War supposedly being a resource hog like Crysis I'm debating utilizing my SLI. I could be mistaken about it being a big resource whore though I'm not too up to date.
Questions
1. I've read that dual sli only supports two monitors while enabled, is it possible to seamlessly transition from SLI when I'm gaming, back to normal multi triple monitor use while I'm not? i.e. Can main 30" and 22" be plugged into the "main" video card while still having the 20' hooked up? I'm confused a bit on this and the sliZone doesn't seem to clarify (or I missed it).
2. I've read that you can create "custom settings" such as for Crysis, or COD4, does this mean I can create Empire:Total War which would shut down my alternate monitors to focus on gaming, and then create a Poker which re-enables everything? Transitioning 3 monitors to SLI is what I'm worrying about a bit. Don't want it to be a hassle.
Maybe just wait and see how the 9600gt runs it and then consider.
Thanks
Questions
Thanks
