SLI Question
The Donut
Hey,
I am going to be saving the pennies for the upcoming A8NSLI-Deluxe and 2x 6800GT's, however I was wondering that when in SLI do I get to use the 4 outputs as 4 multi displays or would it result in only 2 being available?
You will be able to use all four monitors. MaximumPC already tested that configuration.
Yeah, I believe only the top 2 output's work...the second card disables the video and simply focuses on being a second powerhouse
I wonder if it is a driver limitation, that may have changed? The MaximumPC article never referenced any gotcha with the four monitors and SLI. I will have to look once again.
It'd be nice for a driver feature to be able to enable/disable SLI with a few clicks. That way when you wanna play you can enable, then disable to re-enable all four displays.
