Sli Question
haadij404
it will work but keep in mind the different speeds. one is clocked higher then the other. if you are going to clock it up will it be stable? keep these things in mind.
|CMF|SoulAssassin
yeah thats the only thing that throw me off, the Memory Clock
Mine is - 1700MHz(effective)
And the one i might buy is
Memory Clock 1600MHz(effective)
Then the model our not the same
Mine is - 640-P2-N825-AR
Other is - 640-P2-N821-AR
Everything else is the same, so I'm wondering will this cause in instabilities issues ?
cannondale06
with that Athlon 64 X2 5200 theres no point in running those cards in sli. that cpu doesnt have the power to keep two of those cards happy.
