Dec 13, 2006 #1 S Slow Weaksauce Joined Mar 28, 2002 Messages 122 Is it possible to run 3 monitors on SLI? I currently run 2 20" LCD's, I would like to hook my 37" LCD TV up (Via DVI) so I can watch movies from my computer on my TV. Would this be possible? Thanks.
Dec 13, 2006 #3 S Slow Weaksauce Joined Mar 28, 2002 Messages 122 wee96 said: SLI only uses one monitor. Click to expand... hmm, thats no fun... Assuming I just have the two cards, not SLI'd (not bridged) this would work, correct?
Dec 13, 2006 #4 O ohgod Gawd Joined Mar 4, 2004 Messages 620 Yeah, or you can have the cards connected and just have it set to multi-monitor and disable SLI.
Dec 14, 2006 #5 W wee96 2[H]4U Joined Sep 5, 2005 Messages 2,165 Yea if you dont use SLI, you can use more than one monitor no problem.
Dec 14, 2006 #6 revenant [H]F Squad Captain Joined Apr 10, 2005 Messages 16,308 the best way to get around this issue is buy an inexpensive pci video card to run the other monitor(s)..
