Thinking of getting a second GTX 470 for an SLI setup but I am concerned about the amount of power I might need.
I have utilized the eXtreme power supply calculator to the best of my ability and it shows that with my current desktop setup I should run @ ~650 watts required with a 2X470 SLI setup, so I should be ok there.
Would OC under SLI be a possiblity with my current PSU or would that be asking way too much? How much headroom power is needed to be considered "safe."
My specs:
Mobo - ASUS P6X58D-e
CPU - i7930 @ 3.8GHZ (1.24 vcore)
Cooler - Xigmatek Dark Knight
PSU - Corsair HX750W
RAM - 6GB OCZ Gold
HDD - RealSSD C300 64GB (OS)
HDD - CaviarBlack 1TB Sata III (Storage)
EVGA GTX 470 Vanilla (OC'd 774/1800)
USB Peripherals - 5 or 6
Case - CoolMaster 690II
Thanks.
My specs:
RAM - 6GB OCZ Gold
Thanks.
