sli power supply question
kevinf
will a xclio 450 watt work with the A8N-SLi premium. with or without sli. or will i need an sli certified cpu
If you aren't running SLI, then you don't need an SLI certified PSU.
If you are running SLi, you don't need a certified PSU so long as you've got one that can handle the power output. That's the real trick.
kevinf said:
do you know if the xclio will work
With what?
A particular board? Of course. An Asus A8N SLi will work with a measly little Deer 250W power supply, truth be told.
What matters is what you put IN that board.
jonnyGURU said:
With what?
Eek! But would you trust your board to the Deer?
i meant if my xclio 450 watts can handle sli on the asus a8n-sli premium
We still need to know what it will be powering exactly. Everything because you are going to be pushing what I would be comfortable with in all honesty.
Apparently, the composition of your PC is a top government secret that you're not at liberty to disclose.
I understand completely. Do have a nice weekend.
