Thinking about a new rig for gaming.
My monitor is the 37" Westy that does 1920 x 1080.
Will one 8800GTX keep me on top of the mountain for a while, or do I consider 2 of them for the next system crippler like Crysis? I keep reading that 2 only start to make a difference at 1980 x 1200 and above.
Looking to play mainly Quake Wars, COD4 and Halflife Orange Box type stuff. Some RTS.
IF I go SLI, then I will order the MSI P7N Diamond.
If not, then either the Gigabyte GA-EX38 DQ6 or DFI LP LT x38-T2R.
I plan on using either a Q6600, Q9450 or Q9650 for a processor.
4 or 8 Gb of Corsair Dominator 8500C5DF 1066 RAM.
Two Raptor 150's in raid 0 for main drive.
AuzenTech Auzen X-Fi Prelude 7.1 soundcard.
Vista Ultimate 64 bit.
Maybe watercool if noise level or heat make it necessary.
Also, is it true that on the 780i boards, I can go SLI with the first (blue) slot and the third (white) slot? I don't want to lose the only PCI slot on the MSI board. I wish it had 2 PCI slots and more SATA headers.
Thanks for any info/input.
