Well,
I plan on buying another video card soon, one w/ 512vram. I'm waiting for E3 to come around, hoping either ATI or Nvidia will release something new, then I'll buy it.
I'm preferring Nvidia, because I have a SLI compatible mobo.
So, if the PPU and GPU were the same price (probably not, but just per se), would you get a second GPU and go SLI or get a PPU? I have a Xfi sound card, so not sure how the PPU will fit w/ the sound card + GPU, etc. I don't have a NIC though, as I'm using the integrated network card on my mobo, so that saves space.
Also, I like to play games at high resolutions, and 1600x1200 is usually the minimum resolution, that's why I was thinking SLI, etc. Nvidia is supposed to release the driver for the SLI physics, so we shall see how that turns out.
Opinions, comments?
Opinions, comments?
