are you speaking from experience? Source?yep it works, it is not sli.
It will work. The 7950GX2 does SLI internally between the two boards. It has nothing to do with your motherboard. It will work fine. This I can assure you.
I'd never buy another NVIDIA motherboard again if this was possible using an Intel chipset.
Yeah I once had a GX2 and it's designed to work with one PCI-e slot, thus not requiring a SLI board.
Also, there are modified drivers allowing you to run SLI (real SLI, e.g. two 8800GTXs) on 975 or 965; Google it. The drivers are based off old Nvidia drivers and overall performance will suffer. I've never tried it, but I've seen enough to believe it.
I also had no problems with the 680i other than its high price and high heat/noise output.
