SLI not working/installing?
kMaN_(KYA)
I can't seem to get the SLI enabled/installed/working on my newly built system.
Both vid cards have the power plugged-in. THe eVGA mobo has the power plugged-in to power the SLI configuration. I have the SLI bridge connected. I am also using 81.98 drivers. THe SLI doesn't seem to recognize or anything. I've tried the cards in single mode and they both work?
Can anyone help with this?
eVGA NF-41 SLI
A64 4800+ X2
2 gig Corsair XMS PC3200
SB X-Fi Fatality
Win XP SP2
Try some new drivers....I've had issues with this before and when I switched to new drivers it detected them...
Your cards will work in SLI without the bridge also... if you disconnect that you will get a message that says the cards will work better with the connector... (FYI)
Does your motherboard have a jumper (hard of soft) for SLI? My DFI board had huge jumpers to change from a single card, to SLI. I would check the manual to see if there is an onboard jumper you need to manually change, or if there is one in the BIOS.
I figured it out. I also like using a PCI video card for a third monitor but that PCI card was keeping the SLI from working. Does anyone know a workaround for this?
Nope, I dont believe it works. I havent tried it, but have seen several people posting that it doesnt work. As of right now anyways.
