Silent Assasin
- Aug 1, 2004
Ok, so a friend asked me to build him a computer and said that he really wants SLI. But then he only gives me a bugget of $1100 and very maximum up to $1400. My biggest question about SLI is power consuption. I've read in several places that SLI would need a VERY MINIMUM of 500W. He already bought his case that has a 450W. So far what I have picked out for him is the DFI Lanparty UT nF4 it's socket 939, so I matched him with an Athlon 64 3500+ (Newegg was asking another $90 for another .2 Ghz). I've also got 2 gigs of OCZ Memory. Now I'm starting to hit the budget. He knows a little bit about video cards but not a whole lot. So now he's asking for 2 7800GTX's....... I don't think it's worth the extra 100 bucks per card so I decided to get an eVGA 7800GT. And I think I talked him into only getting one video card for the time being. Otherwise he'd be up to about $1500 with these parts. The curent total after shipping is $1,188.80. I've also got a Light-on DVD burner and cheapo $5 floppy drive..
Now the question is, is SLI really worth it at this point? And even if he does and when he does get the second video card, how exactly do you go about setting it up so that it takes advantage of SLI and both cards. I've read quite a bit on the subject, but nothing about setting it up. Part of which I read really suggested the DFI Lanparty boards and they had great reviews wherever I went..... And then power consumption, will a 450W even cut it for a single 7800GT? His PSU only has 20 pins mobo with a 20-24 pin adapter which I've heard can be bad. I told him to start looking around for some 550W and higher and gave him some specs to look out for, but he's really trying to save some money.
