MyFirstSLI
- May 22, 2006
Are there any SLI motherboards which support 8gb (or 16gb) or RAM, 3gb/s SATA, dual pci-express x16 slots for vid cards? possibly a dual amd?
MyFirstSLI said:I play games, do extreme HD video editing as well as regular and 3d graphic design.
on 939 Abit AN8 32X (8Gb) & no doubt it's replacement on AM2.MyFirstSLI said:Are there any SLI motherboards which support 8gb (or 16gb) or RAM, 3gb/s SATA, dual pci-express x16 slots for vid cards? possibly a dual amd?
Ockie said:Why don't you look at a dedicated workstation workhorse and a gaming machine instead of making an all-in-wonder?
If you want it to be all one machine, then you're going to be looking at upwards of 10k+ for the box alone.
You'd be wanting something like a dual opteron motherboard and that alone would set you back $500-600 dollars for a decent one.
MyFirstSLI said:Show me an all in one config that would cost 10k+...
BUFF said:on 939 Abit AN8 32X (8Gb) & no doubt it's replacement on AM2.
Neither will have dual CPU sockets though.
AN8 32X is a good board as well![]()
Tyan Thunder K8WE,
AMD Opteron 285 (two)
Eight 1GB Registered/ECC PC3200 DDR...
Total price: US$13,585.57, not including shipping and handling (4/10/2006, no OS)
Without a doubt the problem that you are going to find is finding the 2Gb DIMMs.MyFirstSLI said:http://www.newegg.com/Product/Produ...2307859+1052407862&Submit=ENE&SubCategory=147
will either of these work with that board? I dont think they will... the board says ecc/non-ecc unbuffered mem and these are both ECC registered.
Because the AMD memory controller spec. has it to scale back bus speed by default.MyFirstSLI said:Why do you think the memory controller would choke on the memory?
