SLI gtx260
crazymonkee84
Can anybody tell me if I can SLI
an EVGA gtx 260 core 216
Part Number: 896-P3-1265-AR
Part Desc: GeForce GTX 260 Core 216
and
an XFX gtx 260
576 MHz Core 896 MB DDR3 HDTV Dual-Link DVI
(GX-260X-ADJA)
Thanks in advance!
I am 95% sure you can.
It does not matter if they are different brands, if that is what you are asking :)
I think you're good to go, so long as its this same chip sets you're SLI'ing
Let an SLI guru confirm this for you, unless I'm wrong (please correct me :) )
Thanks!
I know that the brands don't matter but I know there were two revisions of the card.
The one with core 192? if that's the right number, and the core 216, which is the evga one I currently have. Not sure how many cores the xfx one has though...Can anyone confirm that the two cards will work?
The ADJA is a 'core edition' which usually denotes 216 cores. They should SLI fine.
