SLI "Green Sync Scan Lines" Issue; Please help
vipeness
Hey Everyone...
*** sorry mod... didnt post in the nvidia directory. if you could delete the previous one
I have a XFX 9800GTX card, and a PNY 9800GTX+. My Motherboard is the Asus P5N-D, with 4G RAM dual channel running Windows Vista Ultimate 64bit. All drivers and bios are all updated including newest nvidia drivers. I have a 700 Thermaltake power supply.
I have hem enabled for SLI, first time btw; anytime I bring up a game, it brings up these terrible green sync scan lines and move very fast, like something is outta sync. For example, if when I load Crysis Wars, or Far Cry 2, it shows up in full screen. If I pres ALT+TAB during game or loadup, it goes into window mode and is fine. Only full screen, does it display the green lines.
I do not know how to fix this. Thiis is not the setting in Nvidia Control Panel -> 3d setting to show the sli visual indicators. I turned that on and off and it did not change the green scan sync lines. This look like thousands of green lines moving very fast. Here are the pictures of what it looks like when I load up Crysis Wars.
Well, then is it stuck with that option somehow on. I found pictures of the option on, and it looks just like yours, but without the green lines. It has that bar at the left and SLI next to it.
yeah i wish it woul go away, its nasty! i fixed this issue, i moved the 9800GTX+ to the top slot and moved the 9800GTX to the bottom slot. this is now fixed.
