SLI dual rads?
Introvert
Im thinking about finally sucking it up and going SLI with 2 7900gts and 2 MCW60s on a modded DFI Ultra-D. I currently have a single 120.2 rad in a stacker and was thinking about throwing another one in there for the SLI so my loop would look like this.
Pump > Rad > CPU > NB > RAD > Vid1 > Vid2 > tline/res
equipment in line currently:
D5
MCR220
MCW60
EK-WAVE CPU block
EK NB block
curently a res but will probably go tline with dual rad.
I'd recommend Dual Rads Or a single double fan radiator if you're going SLI. Order of the Rad's seem fine.
i currently have 1 dual 120 rad, i was more curious about adding another. ill have to look into it.
A thick dual 120mm radiator should be enough, are you running a 2" thick heatercore or a thin radiator?
Yeah that's not a 2" thick radiator, so another one might be a good idea unless you want to put a lot of air through your current one.
