SLI-DR Owners...
orkan
I have been working on overclocking my new system. DFI SLI-DR w/ winnie 3200.
I noticed something that may help you other SLI-DR owners. The CPU VID Control and CPU VID Special do not always work correctly. If I set my VID control over 1.425v, the VID Special will not function at any setting. (verified by multimeter)
If I leave the VID set at 1.425v, all VID Special settings work perfectly. (+/- .01v)
This was really screwing me up, as adding voltage seemed to do nothing for stability. That is because more voltage was not actually being applied. :) I have mine topped out at 2750mhz for now.
I believe a guy over at xtremesystems had a table of all the settings that voltages they do get. The VID error is know by DFI, but I doubt they can fix it on all the dispatched boards.
