I described (with pics) some ventilation problems I'm having with my Wavemaster case in this thread: http://www.hardforum.com/showthread.php?t=918864&page=2&pp=20
I'm also worried that the 1/2 inch gap between my first dual-slot 6800 Ultra card and the second one, and the 1/2" gap between the second Ultra and my Audigy2 ZS aren't conducive to optimal GPU cooling.
I'm reluctant to undertake trying to install a radiator in my already crowded case, so am hoping to avoid water-cooling.
I will probably install a couple 80mm fans in the side cover to bring more cool air into the case, which might force some air between the cards, but dont consider that a 'proper' solution either.
The only remaining option I can find would be a pair of Arctic NV Silencer 5 R2's. They are apparently low CFM and cool about the same as the stock heatsink/fan, but do duct the heat out the back of the case. That would help my case ventilation problem, but I'm not sure it will improve the GPU temp readings I get now with the case side cover off (or maybe the offset location of the Silencers fans would exhibit better air flow than the 'clogged' stock fans?).
My question is: Does anyone know of another higher-CFM option to duct heat off SLI cards out the back of the case? Or just any other feasible option? (I am not particularily concerned about decibel levels).
Thanks.
Thanks.
