SLI Confusion
dye4metal
Alright so im buying the MSI Neo4-F SLI Mobo and a 6600 geforce for SLi? And i was wondering do i need anything else. right now ill be running just 1 card. and probably get a 2nd later. wat will i need now and when i buy the 2nd.
haha im on the limit right now for money. ive got 600 dollars im spendingfor my bday on this stuff so i cant do it now. haha later ill try to get one.
also can u tell me wat u need with the SLi ready PSUs like it said Sli ready, wats that mean its got. i got a 500watt PSU so.
What kind of PSU and whats the rest of your system specs???
:confused:
Im Buyin this
AMD 64 3200+
MSI Neo4-F SLi
WD 80 Gb
PC 3200 1gb
Chaintech 6600 SLi supported
my PSU is a Logisys 500watt
but wat would i need to run SLi? I see theres a different power hook up. Why this and can i get an adapter?
Get a 6600gt and a little less expensive hard drive it'll be worth it. Also your mobo might come with power adapters look and see.
Alright man lemme help you out you are confused you have PSU right. Cause that is a 6600LE a very bad card. How much money do you have to spend and what do you already have.
I looked up your PSU your gonna need a new one for sli. Like the one the guy above posted its very good
ill look around for the GT but the WD is 50 bux with 8mb Cache and shit. i couldnt pass it. vs my broken 20 gig... but for right now can i run it? my PSU has a 6 pin flat connector? is there any adapters?
but like i said. wats so special about the SLi PSUs? and my card doesnt have that power hookup so i dont need the PSU right now. and do i have to run the 2 same cards?
Your PSU doesn't have the hookups modern pci-e motherboards need like 24pin, molex. It is better to make the investment now than to waste money on a adapters for a generic PSU. And the video card you selected isn't worth setting an sli rig for. Believe me or take a second opinion you'll get the same answer.
You should be able to mix GPUs when NV 80xxs drivers come out, mabey somtime next week or the week after. ;)
i foudn it on zipzoom with my mobo but newegg the mobo isnt in stock and they charge shipping but on zip they have no shipping charges for 2nd day! but the PSU is out of stock. but ill be ordering it.
yea it is. im waiting for zipzoom to have back in b.c im buying my mobo there too.
yea, any one no how long it takes for most these companys to get them in stock?
