SLI Colors?
HaX
ok so i just got one of my cards back from an rma.. besides the annoying fan buzzing at higher speeds been working fine. that was until i enabled SLI and then my colors on my monitor changed. when i ran the card by itself it was fine... any ideas? I have tried reinstalling the latest nvidia drivers to no success
System:
Q8200 (stock speed)
8GB DDR2-900
2x 40GB Kingston SSD's in raid 0
2x BFG GTS 250's in SLI
XFX 650 Watt PSU
more updates:
i dunno how helpful this is.. but.. when i unplug the vga cable and plug it back it.. and computer finds the monitor the colors are back to normal. after that i tried running metro 2033 and sli was working fine... then i decided to enable Anti Aliasing.. and then the colors got messed up again.. any ideas?
ok so i think it has something to do with me using my HDTV as a monitor and using the DVI to VGA changer to output to VGA to my tv.. when i use a actual computer monitor (borrowing) and use DVI i dont get any problems. Wierd... anyone have any input on this?
sounds the me like your DVi-VGA cable has a pin broken/Not making contact.
i dont get it though.. it's only when using SLI that it does this.. and it's when i change settings in-game
