Some Llama
- Aug 6, 2001
Hello,
I just bought an Nforce motherboard that has support for SLI for a new system i am building.
I figured with support for dual cores and SLI, this would be agreat way to ensure future upgradability.. my concern is that the current video card i just bought might not support SLI.
Looking at the motheboard manual, it tells me that for SLI mode I need to put 2 video cards in and then connect the SLI Bridge connecter on the gold figers of each card, the problem is (as you can see in the link) the video card doesn't have the gold fingers...
So my qustion is, do I really need the bridge connector in order for SLI to work?
The newegg information says the card supports SLI but yet it doesn't have the gold fingers.. ?
Let me know if I need the bridge conector because i'd rather build the system now with one card and then be able to buy the same card later to do SLI rather than 2 new cards when i am ready for SLI...
Thanks,
Some Llama
Thanks,
Some Llama
