SLi and Overclocking
Breex243
OK, so I'm having MAJOR issues with my SLi system right now--I want my video to come out of the bottom VGA, so that's working fine, but when I boot, I have to have one of the monitors plugged into the top card to see anything. That's the least of my problems, though, but a symptom I thought was important.
So I've got a 780i, e6750, 2*2GB of 1000mhz RAM, and 2*1066Mhz RAM. RAM is run at 1000Mhz, 5-5-5-15 (stock for the slower stick). Pumping 1.4V into the FSB and 1.43V into the cores...however, I just CANNOT overclock. I was able to hit a FSB of 1500 once, but I can't change it to any higher. I was at 1700FSB easy, and now with my WC setup and SLi, I can't go anywhere near that speed. What gives? Do I have to disable SLi?
try bumping up the northbridge voltage..
btw for the video not showing on boot using the second card.. try looking in the bios if you can force it to use a specific pci-e slot for the first display option.. by default its set to the first slot..
