OK heres my question. I dont see why you "HAVE" to have 2 of the same cards for SLI and crossfire....
Why cant you use 1 7900 GTX, and your second card being a 7900 GT? Why exactly do they have to run at the same speed?
Also I have heard that even if you have 2 512 MB cards, thats with SLI/Crossfire you still end up with only a total of 512 VRAM. Well why cant they create a second card lets say the same card you have but with 32 mb of memory (will save quite a bit of cost) and that way its still processing and doing everything its needs to do and costs so much less? I think it would make SLI more available to the main stream based on pricing? Basically only the first card is being used memory wise so why waste the extra power on the second card?
