SLI and borderline PSU, dangerous?
schoenda
So I recently threw a second 7800gtx 512 in my FX-57 based system...For curiosities sake I left my Antec 450watt PSU in to see what would happen, I fully expected to have an unstable system..but I dont. Everything seems to be in spec re voltages and I gained 2000 3dmarks...running all the games with no instability.
My question is this somehow dangerous or will it shorten the life of anything in my system besides the PSU? I don't really care if I kill the PSU because the next step would be a bigger one anyway.
Please help before I blow myself up. As always I thank the smart people for coming to my rescue.
Dave
It is indeed a Smartpower 2.0...It came in my Antec Sonatta II case. Very nice case if I may say.
seriously wouldnt suggest it but... i guess it works.... but i still would recommmend getting a sli certified pcp&c, great psu's and that psu prob will ber out of the back of ur head
Um, it should be fine. PSU's seem to be one of the things that are always OVER reccomended on the watts scale. Add up all the watts, if you're less than 400 (and the rails are fine, read with a multimeter) watts you're gravy.
QFT. But i'd say he's better off adding up the 12v amps required.
12Va is 15A max and 12Vb is 17A max on his PSU. 32A on 12v can power 2 7800GTX 512MB cards (under 18A total), a FX-57 (10A) and a couple drives.
I only use a 350W PSU on an overclocked X2, overclocked 7900GT, 3 hard drives and 2 optical drives.
it realuly depends on how ure psu is made, it could be a quality 450w, but then iagain another person might have a prob with a noname 800w
Thanks folks, I will keep running the Antec for now and if it burns up or something I will give a shout out...
Thanks,
Dave
