SLI 8800GTS... heat issue?
zerog83
So my friend has a pair of 8800GTSs plopped into an Asus P5N-D. He's worried that his video cards are too close together, as the air vents on the back of the case are too hot to touch.
He's also running an Intel E8400 w/ 4gb Corsair memory, a 750-watt PSU and a few other goodies.
He has it all set in this case, which I think is the problem. The giant fan on the side and the not-quite-as-giant-but-still-kind-of-xbox-huge fan in the front both blow in, and only the small fan and the blowers on the graphics card blow out. Seems like that makes for bad air flow...
Any suggestions?
As long as the GPU's themselves gets a good intake airflow, he would be good to go...
Remember the small exhaust fan is only for exhaust of air in the case, such as air to the CPU HSF, RAM, etc...the 360mm intake fan on the side is more than enough for a good intake airflow for the GPUs, which then exhaust the air through the back by the cards themselves
My friend got the same issue. What he did was to add a small fan between the 2 cards.
