SLI 7800GTX's 3DMark06 question...
darthanakin23
ran 3DMark06 at default settings and 1280x1024. I also put my driver on high performance and AA and AF on application controlled.
My Specs are in my sig but i will post them here too...
FX-55 @ 2.76Ghz
Asus A8N-SLI Deluxe
2 gigs of Corsair XMS RAM
Audigy2ZS Platinum
2xEVGA 7800GTX's 256MB @ 470,1.2
These are the settings I ran the benchmark at and got a score of 6,219. Is this a normal score for me?
Anyone able to tell me if my score is too low?
Seems low... I have 7800 GTs and a 4400 and got 6768. Dunno what your problem is though cuz I have hardly any experience with 3dMark2006... Maybe it has something to do with multi-threading :confused:
btw... you sig specs say 6800 ultras. ?
You have a dual core and he doesn't, the cpu is pretty darn important in 06
PC Perspective scored 6006 with 2 7800gtxs with a stock FX55
Chinese, so you think my score is pretty normal? I know that even a dual core 3800+ gets a high cpu score then my FX-55 because it is dual core. But with my system, is this normal?
By the way, I score 12,234 in 3DMark05....
Anyone???
Mark06 seems heavily score dependent on the CPU... your scores don't look that bad...
CPU:AMD Athlon64 FX60 oc 3076.6 MHZ
DFI NF4 SLI DR
memory:MUSHKIN BH-5 Dual Channel ,
2x512M,2.0-2-2-5,1T
WD SATAII 250G 8Mb Cache,
dual 7800GTX512 SLI 680/1970 MHZ + 621/1857 MHz
ZIPPY 800W
3DMark Score 10003 3DMarks
SM 2.0 Score 4605 Marks
SM 3.0 Score 4533 Marks
CPU Score 2348 Marks
http://service.futuremark.com/compare?3dm06=10834
